Raptor stalling
Old Feb 10, 2002 | 02:17 AM
slappie's Avatar
I've got a problem that I hope someone can help with. I've got a 2001 Raptor with a ProDesign K&N intake, Dynojet kit, and Gytr pipe. I've got the jetting at Dynojet specs, I think its 144, 146 mains, stock pilots, 3 turns out on the screw, clip in 4th notch.
The problem is this: When I do a wheelie from a stop (popping the clutch), for a short time and then pull the clutch in and let go of the throttle to bring the front end down and come to a stop it will sometimes stall. I called Dynojet twice and got two answers: 1. turn the air screws out a litle more until the condition goes away 2. Put the needle on the 5th notch. I haven't cleaned the air filter yet but it doesn't look too dirty. I've also got some 25 pilots that I could put in. What do you guys think? I live in Texas and ride at sea level. Other than that, it runs great. Thanks.
Old Feb 10, 2002 | 04:26 AM
RichieRoadRash's Avatar
check ALL your carb hoses. make sure there are no creased places along the hose. happened to me a while back.
Old Feb 10, 2002 | 10:14 AM
Kawi250's Avatar
It sounds like its not getting enough gas, it might be the float height. Did you happen to touch the tab on the floats?
Pehter
Oct 3, 2024 11:00 PM
bmxatv10
Oct 14, 2022 06:23 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
