Raptor bogging out
I took my raptor out for a little while this weekend and noticed that it was bogging out when I tried to accelerate. Im not sure if it just needs a tune up, I havent taken it in to adjust the valves yet because Ive only ridden it about 10 tanks of gas. I checked the oil and noticed I needed some and I accidently overfilled it a little bit past the mark for full. Could that be the problem. Im not sure what it is but after I get past the initial bogging of the engine the thing runs like a champ. If you have any info. it would be apperciated.
Thanks
ERIC
Thanks
ERIC
<< I took my raptor out for a little while this weekend and noticed that it was bogging out when I tried to accelerate. Im not sure if it just needs a tune up, I havent taken it in to adjust the valves yet because Ive only ridden it about 10 tanks of gas. I checked the oil and noticed I needed some and I accidently overfilled it a little bit past the mark for full. Could that be the problem. Im not sure what it is but after I get past the initial bogging of the engine the thing runs like a champ. If you have any info. it would be apperciated.
Thanks
ERIC >>
There is an extreme rev limiter hooked up to the parking brake at the clutch lever. If this isn't adjusted correctly the Raptor will barely run. We have had this problem several times....vibration will unadjust it for you.
HEY SINCE YOU OWN A RAPTOR HAVE YOU HAD ANY PROBLEMS WITH THE RUBBER BOOT ON THE CARB BLOWING OFF. I HAVE A FRIEND THAT HAS AN 01' AND HE HAS HAD THIS PROBLEM TWO OR THREE TIMES NOW. JUST WONDERING. MAYBE THEY FIXED IT FOR 02'. I AM WANTING TO GET AN 02' AND AM WONDERING WHAT YA THINK OF IT
I've had no problems with the rubber boot blowing off of my Raptor. After purchase, everyone should go through there bike and tighten everything in sight to specs after breakin. you should post this as a new question, might get more responses. jmo.
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
