Raptor smoking
Old Feb 15, 2002 | 04:51 PM
  #21
Rudedog's Avatar
Bluish smoke: My initial thought would be valve seals. Oil settles in the chamber after it has sat for a while. Then will burn off when fired up and go away. Also (typically), if it's the rings it won't stop smoking completely. It will decrease a lot, but should still smoke under acceleration. Run a compresson test on it. That should tell you if there's a problem within the cylinder.
Rude Dog
Old Feb 15, 2002 | 04:54 PM
  #22
95Warrior's Avatar
I called Dynojet today and they said the fourth position from the top is the correct one.
Old Feb 17, 2002 | 11:07 AM
  #23
rraptorr13's Avatar
With a slip-on silencer, prodesign filter kit(foam 2 stage oiled fitler) and the K&N jet kit Dynojet said that they have had the best results with the clips in the second position.
bmxatv10
Oct 14, 2022 06:23 PM
EIF
Apr 20, 2017 07:15 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 12, 2015 09:39 AM
