Raptor oil question
Old Feb 14, 2002 | 05:30 PM
elanphea's Avatar
How often do you guys have to put more oil in your raptors? Just curious to see?
Old Feb 14, 2002 | 08:45 PM
rraptorr13's Avatar
Only add oil when doing a oil change.
Old Feb 14, 2002 | 09:31 PM
elanphea's Avatar
so you never add oil to your machine unless you are changing your oil? That doesnt sound right
Old Feb 14, 2002 | 11:43 PM
Smith31's Avatar
Usually u don't have to add any oil if it's not burning it. If it's using oil check it often and add when needed.
Old Feb 15, 2002 | 12:09 AM
rennym's Avatar
You shouldn't 'add' oil. You should fill when you change it. If you check it and it's low, you either have something wrong with your motor or you haven't ever changed your oil, or when you filled it, you didn't follow the filling procedure properly.
You need to frequently change your oil. You only have this little amount in your engine, so it's important that you do it often, and follow the filling procedure.
It's kind of a moral. At the very least you should never have to add oil, because by that time you should have changed it anyway (or 5 or 6 times before it got this way). Or something is very wrong.
RM
Old Feb 17, 2002 | 11:01 AM
rraptorr13's Avatar
Why wouldn't it sound right my machine is well maintained and does not leak or burn oil. If it was then that wouldn't sound right because then there is a problem .
Old Feb 17, 2002 | 12:19 PM
skramblr's Avatar
Had my Raptor almost 1.5 years now. Never had to add oil, ever, but have noticed you must check oil level the same way every time. Need to follow a procedure or you may find your oil reads differently.
Old Feb 17, 2002 | 07:09 PM
Raptorguy's Avatar
Just on the issue of checking your oil the same way everytime. Yamaha manual says that when checking your oil, do not screw the dipstick into the sump. The oil should be checked by just placing the dipstick in the sump. Not screwing it in like you were sealing it up.
Firefighter400
Oct 8, 2022 06:38 PM
Aug 21, 2015 01:23 PM
black_thunder
Jul 22, 2015 06:01 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
yambam13
Jul 4, 2015 01:49 PM
