K&N power jet kit ( Raptor)?
Just ordered my power jet kit for my Raptor just wondering is thier any pros or cons on installing kit how long should it take and what jetting did you go with, stock raptor (for now) thanks for your help.
Also was going to adjust the valves any info on that also would be great, thanks again.
01 RAPTOR
02 250ex(sons)
01 RAPTOR
02 250ex(sons)
If your jet kit is the Dynojet or K&N Stage 2, follow the enclosed directions. Install time takes about two hours, with most of that dis-assembling the plastic, removing the tank, air box, etc. The kit is well worth the money, as you'll find out as soon as you ride it. It will pull harder and have a quicker response to the throttle input, even with the stock pipe.
For the valve adjustment procedure check out Adjust Raptor Valves The intakes aren't to bad, the exhausts are tough just because of the lack of room to work. My intakes were tight, the exhausts were okay, so I lucked out.
