how 2 install a sprocket
Old Feb 21, 2002 | 05:51 PM
warrior4969's Avatar
i just got a 12 tooth front sproket for my warrior and i want to know how to put it on
Old Feb 21, 2002 | 05:53 PM
warrior007's Avatar
Maybe you should take it to a mechanic if you dont know how.
its a washer and a nut.
Old Feb 21, 2002 | 05:57 PM
that justs wastes $ that i dont have icould do it but i just want to do it right so does any body have any ideas on how to and what to use
Old Feb 21, 2002 | 11:14 PM
wshrdskin's Avatar
Haven't seen a Warrior up close. I'd assume it has all the same stuff. Take the sprocket cover off. Un bend the washer that keeps the nut from coming lose. Take the nut off. Pull the sprocket off, it should come off without taking the master link out of the chain. Put the new sprocket on, then the washer and nut. Tighten the nut, re bend the washer against one side of the nut. Tighten the chain to the correct tension. Geez people, not everyone is a gear head.
Old Feb 21, 2002 | 11:30 PM
who are u referring to on the gear head stuff. i thank you for your help
Old Feb 21, 2002 | 11:39 PM
wshrdskin's Avatar
Just a little remark towards the rude response you recieved. I left out the part about putting the sprocket cover back on. Don't forget that. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Feb 22, 2002 | 12:20 AM
thanks man i just got back from putting it on i havent bent the washer back. thats the hardest part about it.
ReconBayou
Oct 31, 2022 05:37 PM
buddieboy
Dec 9, 2016 05:50 PM
2many2ride
Sep 27, 2015 04:35 AM
merryman
Sep 19, 2015 03:15 AM
