Wolverine unlocker?
High Lifter will have its "Unlocker" for the Wolverine available in mid March. They should release the "Unlocker" for the Honda 450 and Rancher in early April.
The Unlocker is a driveshaft replacement that allows the shaft to dis-engage via a machanical lever. From all reports it should be a very reliable unit.
I have looked into the Big Bear diff swap, but I believe that the gear ratios are different and would cause the driveline to bind. Not to mention the cost. The Big Bear front diff from Yamaha is close to $800 and this is without the electric actuator, switches and wire harness. The Unlocker from High lifer will be under $350.
As it is, Yamaha has done great injustice to the almighty Wolverine by not equiping it with selctible 2x4/4x4 from the factory. At least options are finally becoming available.
