help with banshee jetting
Old Mar 1, 2002 | 02:17 PM
leeboy's Avatar
i have just installed pyramid reed valves,duncan racing masterflow system,pro flow air flange with k&n with outerwear,the carbs are stock 28mm,the banshee is year 2001 model,my dealer recomended changing main jet only from 200 to 280,the problem now is that it starts ok ,then when warm say 5 min on tick over you feather the throttle to say 1/4 then it floods .any suggestions thanks leeboy .please note it is running on paul turner midrange pipes and fatboy cans.
Old Mar 2, 2002 | 10:27 AM
WyoDuner's Avatar
Is it possible to get it to rev up at all; like if you didn't let it sit and idle for 5 minutes? The mods you did are nothing out of the ordinary and your jetting sounds right even though your main jetting would have just a little effect on the problem you are having. Tell us a little more and I'm sure somebody can help you out.
By the way, if you leave the Banshee sit and idel for 5 minutes it will probably load up and die or bog real bad when you hit the gas; I wouldn't call that unusual really.
Old Mar 2, 2002 | 12:11 PM
leeboy's Avatar
wyoduner thanks for replying,it revs up from cold but as soon as it is warm it just dies,the carb floats work and the slides are working
ReconBayou
Oct 31, 2022 05:37 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
