raptor
Old Mar 2, 2002 | 12:48 PM
kodiak2k's Avatar
Hey Guys, I use PJ1 chain lube on my Raptor,well I've got it all over the rear sprocket, is there a way to clean off all the dirt that sticks to it? Soap and water doesn't cut it. I want to use an old paint brush and so kerosene (sp?)i'm just afraid it might eat the greese out of the rear bearings. What do you guys think? I don't plan on drowning it just using enough to get the job done.
Old Mar 2, 2002 | 01:34 PM
Sandgod's Avatar
I did the same and had my K&N filter cleaner laying around. The stuff you sparay on the filter and let soak then rinse. It cuts through oil obviously to clean the filter, so I used it and it worked...
Old Mar 2, 2002 | 02:21 PM
kodiak2k's Avatar
Hey thanks, never thought about the filter cleaner will try it this afternoon, wouldn't have chainlube all over if I let it dry like they say but it seems like I always lube it while I'm letting it warm up no time to let it dry Gotta RIDE! Thanks for the help!
Old Mar 2, 2002 | 04:04 PM
3sportsman's Avatar
Use WD40 it will take it right off. thats what I use.
Old Mar 2, 2002 | 05:04 PM
elanphea's Avatar
hey 3 sportsman, how does your acbumber look on your raptor. It it pretty durable. thanks
Old Mar 3, 2002 | 11:31 PM
3sportsman's Avatar
Its pretty durable I have the polished one without the dirt screen.you can see at www.geocities.com/thomas7197/Raptor.html the pictures are hard to see but it will give you a idea.
Old Mar 4, 2002 | 01:51 AM
velocityraptor's Avatar
THE BEST LUBE FOR YOUR O-RING CHAIN IS CHAIN WAX, IT WORKS REAL WELL AND DOSENT FLY OF ALL OVER EVERYTHING, USE ENGINE DEGREASER, JUST KEEP THE ENGINE DEGREASER OFF YOUR CHIN AS MUCH AS POSSIBLE. ITS HARD ON O-RING CHAINS.
Old Mar 5, 2002 | 05:49 PM
Raptorrider2001's Avatar
I have used the chain wax and I think it is a real mess. Hard to clean. I now use Silkolene. I have tried seveal things to clean the chain and the best I have found is charcoal lighter fluid. It is made from Naptha that some places us to clean parts and you can also find Naptha at paint stores. Have not noticed any deteriation of the O rings. Just get you a parts cleaning brush and have at it. Use soap after you have cleaned it. Let it dry and re-lube. I just wish there was an earier way of removing the chain without having to break it and use a master link. It seems like also I have or read of using diesel fuel to clean a chain.
Old Mar 5, 2002 | 09:19 PM
otterbob's Avatar
i use maxima chain wax. the little residue that it leaves cleans super easy with a wire brush.
bmxatv10
Oct 14, 2022 06:23 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
