banshee mix ratio
i just ordered a case of Motul racing oil and i am converting the european liquid measurments to u.s. i seem to forget what the required mix ratio is for a banshee motor. is it 50:1 or 66:1 ??
Also i just rebuilt the top end on the motor. What are the best ways to break in the motor??
thanks in advance
thanks in advance
Shouldn't he go by what Motul recommends and forget about Yamaha? I have always heard that you go with what the oil says.
Are you runnning the 800 2T race oil? If so I believe Motul says 50:1 on that.
I may be wrong....maybe you should use the manufacturers recommendations, but I run AMSOil 100:1 (I run it at 80:1) and have had absolutely no problems. My buddy has run it in his Banshee (he has owned 3 since 1994) and has never had any engine trouble. He has not rebuilt any of his engines so that is good enough proof for me.
Obviously the safest thing to do is call your Yammy dealer then call Motul. See if what they both say the same thing. I know some dealers know what they are doing, but there are also a lot that don't have a clue.
-Josh
-Josh
I agree with Piranha, follow the recomendations of the oil make. Yamaha recomends 32:1 because that is the mix ratio for the Yamalube.
Jul 7, 2015 11:00 PM
