banshee problem
i just got my banshee and i already have problems with it
I was out in the dirt spinnin circle and such. then i pulled out of the spin and downshifted to take off again and then my clutch cable wouldn't pop back out. then i look down and my clutch cable fell off on the case. so i thought no biggie i'll just put it back on. but the clutch lever on the case only moves about 1/2 inch. and the cable doesn't work to well anymore. then i try to move the clutch lever on the case with my hand while in gear to see if it will roll. but the tires are still locked. i can still shift through all of the gear when the engine is off. and now i can't get the motor to start. is my clutch already blown? or is it something else you think.
i tried to describe it the best i could but ask questions if you need more info.
thanks for the help
thanks for the help
Jul 7, 2015 11:00 PM
