Blaster Jetting
Old Mar 9, 2002 | 07:12 PM
Noramsler's Avatar
I have a 91 Blaster that has a k/n filter(no air box lid)Dg pipe,Vito's superstock piston,Vito's jet kit,vito's degree key and 280 main jet.The problem I am having is with the jetting. This is from a dead stop and going full throttle through all the gears. 1st and 2nd gear have no problems. 3rd is somewhat ok until the power band kicks in. 4th 5th and 6th skip. It is like a studder. the motor skips. Should I go down one size on the jet. The spark plug is on the dark side.The needle clip is set in the middle. I will be very grateful for any help.
Old Mar 9, 2002 | 07:16 PM
BlasterMan13's Avatar
whats the degree key do and super stock piston?
Old Mar 9, 2002 | 07:29 PM
Noramsler's Avatar
Vito's performance claims the degree key adds 2.5hp. I did notice a difference in power when I added it. The super stock piston, is a modified wiseco piston. 5hp gain.
Old Mar 9, 2002 | 08:36 PM
SheeMan's Avatar
I beleive I can solve your problem. The gears dont matter, its the throttle position. If its skipping at full throttle, your definately running too rich. Keep lowering the jets untill you can pin the throttle and theres no problems. Also, pay attention to your speed, if your going faster and about 3/4 throttle than full throttle, than your way too lean, but im pretty sure your too rich.
What kind of carb are you using? Look at my mods below, and im only running 220 jets.
Old Mar 10, 2002 | 04:09 PM
Noramsler's Avatar
I am not sure about the carb, I will have to look. I am assuming that it is stock. I bought it used. I went to a 270 jet today and 3rd is now real stong, 4th is better and 5th and 6th are still skipping. I thought that the stock jet for a blaster was a 230. I am suprised that you are only using a 220. Also, I am using a premix at 32:1. I also put in a different needle and pilot jet.
Old Mar 11, 2002 | 06:09 PM
IOWAsheeRider's Avatar
I have about the same mods on my blaster i put a 260 jet in it and it runs great but it does depend on the elevation! but i would say you definatley need to experiement with a smaller jet.
ReconBayou
Oct 31, 2022 05:37 PM
Ahtatu
Sep 28, 2015 12:14 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
nastyblaster100
Sep 13, 2015 01:19 PM
