RollDesign Raptor Shifter
I received my RollDesign Raptor shifter last week. Finally got around to put on the shinny shifter this weekend, but unfortunately it didn't fit properly. The only way to get it to clear the crankcase cover is to have it way low. At this position you can forget about up shifting with boots and stock pegs. It's difficult to down shift to first from neutral as well because it will hit against the frame. Moving it higher it will rub against the crankcase cover and not able to up shift.
Has anyone bought this shifter and experienced the same thing?
BlueReptile:
Does your new Roll Shifter not hit the sprocket cover when you shift up? Also, is it not too short? I ask because I just got mine from Roll and it is about an inch too short (1 inch shorter than the stocker) and if you have it high enough for your boot to clear, when you shift up it hits the sprocket cover. This one was from the new batch from Roll too. Let me know.
Slappie,
You're right, the shifter does hit the sprocket cover when up-shifting. I didn't even bother to check the clearance after I installed it. I went ahead and cut out part of the sprocket cover and now it clears. I really haven't ridden it with the new shifter, may have to get use to the shorter shifter with boots.
Thanks for the post guys, I had just ordered one last Sat & luckily it is on back order, I cancelled the order tonight, will put the money towards new front shocks or rear axle, something that fits & works I hope. I sat on a CR250 & it shifts up/down real smooth, wish they could make a shifter that works & fits at the same time....
