Raptor 2002 Trans. Gear Ratios
Old Mar 23, 2002 | 08:12 PM
Pull's Avatar
I'm trying to find out the 2002 gear ratios for the raptor, people tell me they are different from the 2001. Can anyone help me out and give me the actual ratios to check them against my 01 repair manual.
Then a can calculate the actual difference. Looking to change my gearing since my shifting fork bent inside the trans. The 2001 ratios are as follows:1-2.428, 2-1.526, 3-1.238, 4-1.047, 5-0.904, R-1.750
Thanks for your help.
Old Mar 23, 2002 | 09:36 PM
THEMOOSE's Avatar
These numbers are from the Raptor factory service manual 2002 supplement.
1-(31/12) 2.583, 2-(30/18) 1.667, 3-(27/21) 1.286, 4-(22/21) 1.047, 5-(19/21) 0.904, R-(33/25 X 25/18) 1.833.
As you can see 4th & 5th are the same as are the sprocket sizes (40/13) & the primary reduction ratio (71/34) 2.088 the numbers next to the gear ratios in () are the number of teeth on the gears.
Hope this helps.
Old Mar 24, 2002 | 09:32 AM
Pull's Avatar
Thanks for the quick response "THEMOOSE". You made my day!!
Firefighter400
Oct 8, 2022 06:38 PM
Ashley S
May 29, 2017 10:54 AM
black_thunder
Jul 26, 2015 09:23 PM
coolguy420
Jul 10, 2015 01:17 AM
black_thunder
Jul 9, 2015 05:58 PM
