Just have a few questions?
Old Mar 26, 2002 | 01:50 PM
sparkster's Avatar
Can someone please answere a few questions I have about banshees
1. Are boysen reeds good.
2. Is a toomey jet kit good and can you use it with any set of pipes. Also how much does one usually cost?
3. Are boost bottles worth buying
4. What are the coolest graphic kit's out there and were on the net can I take a look at them and there cost's.
5. How many paddles should I get when I buy paddle tires for it.
Thanks
Old Mar 26, 2002 | 05:01 PM
WyoDuner's Avatar
No, not really. I can't tell a difference. Stay Stock, I'm going back to my stock reeds.
Well, the jet kit is designed to match the power curve of the pipe (the needle taper does that). Would probably work fine with any other top-end pipe. Honestly, Jet kits by themselves are a rip-off. If you get them with the pipe then fine but don't buy separately.
Not at all. Anybody who tells you different is imagining a power increase.
Next question that matters....
Thanks
If you are piped then 10 paddles is the max. It depends somewhat on your tire size. for a 20" tire 10 paddles works OK but on a 22" tire I would think 8 paddles would hook up pretty well too.... I run 20" 10 paddle tires now. Next set will be 21" 9 paddles or 22" 8 paddle tires.
If you want worthwhile mods consider the following: Pipes, Pro-Design air filter flange, milled head, +4 degree key, Skat Trak Haulers for paddle tires; all the rest pale in comparison.
Old Mar 27, 2002 | 01:54 AM
sparkster's Avatar
Thanks for the help.
Does nyone else out there have some comments about this. They would be greatly appreciated.
EIF
Apr 20, 2017 07:15 PM
shimanok2
Jan 29, 2016 07:37 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
