Warrior V.S. 300EX
Definitely go w/ the Warrior. People might say they are heavier but if you look at the specs on each the difference is only 20 lbs. Warriors are faster, but dont handle quite as well. They can still beat 300's through the woods w/o a problem. They are longer and thus more stable for hillclimbs. When mine was stock w/ exception of RaZr's I could hang w/ a 300 (w/ pipe, RaZr's, K&N Jet kit and other goodies) until 3rd gear when I blew him away. You'll be a whole lot happier w/ the Warrior over the little insignificant Honda.
#17
#18
#19
#20
i had a 300 ex before i got my LE Raptor. the 300 ex is a nice bike and i recommend piping it,jetting it and putting on a different air filter this really picks the bike up alot.this does away with first gear though so go up a tooth on the counter sprocket.you are going to eventually want a bigger quad so i recommend if you have the financing to step up to a 400 ex you will be happy you did.the 400 ex gives you the best value for the money.I would recommend the 300 ex if you don,t want to spend the money for the 400 but for a $1000 more it is worth it.The nice thing about the 300 is that mods are alot cheaper you can get a complete pipe for a little over $200.if you have any questions about the 300ex contact me.
