Raptor Jetting Questions /Which Pipe (New Owner)
Get the yoshimura. If I was to do it over again that's the one I would get. I have the White Brothers e-series, the blots that hold the disc in have sized and I had to cut one out. I don't think it is going to last very long. I would wait and install the jet kit with the pipe, this way you will know the money was worth it by the jump in power. But that's just me[img]i/expressions/face-icon-small-happy.gif[/img]
radman, you need to use anti-seize on all connections where extreme heat is involved, Exaust slip joints, all exaust bolts, spark plugs, etc. This simple step will save a lot of headaches down the road. I also changed all hardware on my exaust to stainless steel, just another preventive matinence step.
My Web Site
My Web Site
#17
airraptor
I usualy agree with you though I may not post it. On this I cannot.
<< get rid of the k&n power up kit and the dyno jet kit also. only use stock jets and stock needles. >>
I was running mikuni jets for a long time. I finaly broke down and bought the K&N jet kit. Not the power up kit. These are Dynojets. I used all recommended springs, needles, clips and jets and the difference is very noticable. I am currently waiting on some larger jets as I am running lean. I used to run 150/155 mikuni jets and the current 146/148 dynojets exceed the power I used to have. I ran as large as 170/175 mikuni and the bike didn't run properly. When i get the proper jet sizes installed i would expect to notice a bit more improvment on what I already have. You can skip the pro flow and use a stock style K&N but I wouldn't skip on the Dyno jet kits. JMO
#18
