Rich stumble at 1/8 to 1/4 throttle..Help?
Old Apr 15, 2002 | 11:55 AM
mjos's Avatar
Hey all,
I'm getting a rich condition stumble in my throttle between 1/8 and 1/4 and a very slight backfire on decell.
Would it be best to lean out the A/F Mixture screw or drop the needles down a position (raise the clip)?
Other than that, she runs real strong at 8000-9000 ft.
Current Settings:
A/F 3 turns out
Dynojet Mains: dj142, dj144
Dynojet needles on groove #4 from top.
Thanks,
Mark
Old Apr 15, 2002 | 12:24 PM
garyc660R's Avatar
Does your headpipes glow when idling? What does your plug look like after the machine idles for a short period?
Old Apr 15, 2002 | 01:04 PM
mjos's Avatar
No glow on the headpipe. The plug is black (rich) after idle.
Mark
Old Apr 15, 2002 | 01:20 PM
garyc660R's Avatar
Yep, definately rich. Adjust the air/fuel mixture screws in to about 1 turn out each, then check the plug after idling a while. You still want a slightly rich condition at idle too help prevent the carbs from blowing off. I would'nt mess with the needles until the plug is slightly rich at idle and the problem still exists.
Old Apr 16, 2002 | 03:28 PM
CBUS660R's Avatar
airraptor, he shouldn't need to change his needles and mains since they don't come into play until you get more than 1/4 throttle (mains at 3/5 to 3/4 throttle). Since he specifically says 1/8 to 1/4, he needs to play with the a/f mix screws. I would try turning them back to 2 turns out.
Jmuddin284
Jan 19, 2026 07:16 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
KSJOHN
Aug 30, 2015 08:15 AM
scott1988
Aug 18, 2015 08:44 AM
Jul 30, 2015 09:39 AM
