MX Raptors...hows yours set-up for the track?
Old Apr 18, 2002 | 11:40 AM
kuz28's Avatar
How wide did you go...+2 a-arms? +3?How wide is your axle...brand?shocks?what did you do to lower it?what gearing are you using with 18" holeshots tires?any weight saving tips?
Old Apr 18, 2002 | 03:20 PM
mudmunster's Avatar
I'll tell you how I want to set mine up...
Houser +2 long travle black lower and chrome upper A-Arms, Elka Quad rate shocks, dual rate rear shock, 11:1 High comp piston (or sparks 690 Kit), LSR +4 axle, LSR +2 swing arm, Graydon Airbox, K&N Filter, Outerwear, AC Pro peg nerfs, AC polished Front Bumper, Denton Rebuildable Stabilizer, Pro Design Kill Switch, Yoshimura Pro Series Tri-Oval, 35mm FCR carbs, Heavy duty clutch kit, Hinson clutch basket, 20X11X9 6 ply Razr's rear, 21X7X10 6 ply razr's front, 19X6X10 Holeshot MX Front, 18X11X8 Turf Tamers Rear custom grooved For MX, Hiper tech rims, LSR Sterring Stem, and some other little goodies
I know the shocks I want will lower the beast and with out making less shock travel.
Hope this helps later
Old Apr 18, 2002 | 05:24 PM
shollz's Avatar
I will tell what I have.
Engine
JE 102mm 12.5:1 (686cc)
Web Cam
Stiffer valve springs
1mm Bigger Valves w/ 3 angle valve job
Flowed Head
Big Gun Exhaust
Pro Design Filter Kit
Suspension
American Star +3" A-arms
PEP ZPS Shocks
Denton steering stabilizer
Lonestar Axle
Tires and Wheels
20x11x6 Holeshot Mx on Douglas .190
18x11x8 Holeshot Mx on Ultimate Beadlocks
Miscellaneous
12T Front Sprocket.
Tag T2 bars
Nac's Parking Brake Block
Custom Mounted Indicator Lights
Graydon Proline Bumper
Graydon Proline Nerf Bars
AC Rear Grab Bar
Black Powdercoated frame
Braided Brake Lines
RTC clutch and brake levers
The PEP shocks are definetely the best shocks made, but plan on waiting about 4 months for them. The only downfall to running the +3" A-arms like mine is that in order to stay in the 50" AMA legal width, you have to run the special order douglas 4+1 wheel (pricey at $84.99 each)if you have zero preload shocks. With the 3+2 offset I can pass tech if I pull up on the front end a take all the preload out. If I ever have to buy another axle it will be an RPM, because they actually make a +4" axle that will get me to 49.5" in the rear, instead of 48.5" . Durablue will get you there, but they are total junk. Last year at redbud, I saw 7 axles break, and 6 of them were durablues. The only mods I still need to do is a +1.5" lonestar swingarm, FCR carbs, Roll design pegs, and a lot more practice time.
Old Apr 18, 2002 | 06:47 PM
54warrior's Avatar
mudmunster, did you say Elka QUAD rate shocks?
Old Apr 18, 2002 | 08:37 PM
rideraptor420's Avatar
here's what i did +2+2 roll design a arms +2+2 lonestar axle durablue lowering kit axis pro rated shocks and i used a size 13 sprocket in the front....i tooled on 3 cannondale moto 440's on the track. do these mods and your handling and power will put you first
Old Apr 18, 2002 | 10:59 PM
mudmunster's Avatar
yes I did.
Old Apr 19, 2002 | 01:51 AM
kuz28's Avatar
Mudmunster: i don't know about the quad rate but if they are anything like my triple rate with piggy backs and self sagging from Elka...they'll make you appreciate your Raptor more.
shollz: i also have +3 A-arms (lonestar) with the Lonestar axle. Is your rear slightly shorter than the front? if so hows it handling the turns with that 686? as it is, i have to be careful getting on the gas in the turns. the rear swings around fast.and i'm running stock.
what gearing do you guys recommend for the track...with the 18" tires? right now i have a 12t in the front.
riderraptor420: i'm interested in that lowering kit. can you tell me more about it?
Old Apr 19, 2002 | 11:34 AM
seven's Avatar
I have a friend that runs a raptor and he uses +3 A arms,wider axle,and tcs shocks to get it lower and that handles great. It is also on ebay right now if you want to check it out.http://cgi.ebay.com/ws/eBayISAPI.dll...tem=1721962406
Old Apr 19, 2002 | 04:08 PM
its made by dura blue the rear is an adjustable strut and its about $98.95. The fronts look like two L shape brackets and they go for $71.95 you can order them from nacs racing www.nacsracing.com or from dura blue
Old Apr 19, 2002 | 04:31 PM
herbdon's Avatar
2001Raptor:
AMA/ATVA &amp; NEATV-MX 2001/2002 member, Bike: #352, Class: open amateur
(front):
Roll Design Lobo2Aarms- Silvervein Power Coated bottoms / chrome tops.
Custom Axis triple rate, dual adjustable shocks with rezzies.
Scott Performance Steering Stabilizer
Roll Design Antivibration Steering Stem
(stock length / chrome stem / black anodized dogbone)
RPM Cyclone billet taper bearing front hubs
HiPer Tech carbon fiber rims (4+1)x10”
ITP mx 20x6x10 tires
TimmyBoy +3 dual stainless steel braided brakelines.
(rear)
Redline Performance Machines (RPM) +2 Swing arm with 250r rear housing –
Silvervein Power Coat.
RPM – 250r fully adjustable taper bearing carrier with grease zerk.
RPM – 250r +4 Dominator axel with race sprocket hub
RPM – 250r Antifade Locknut
Custom Axis single rate, dual adjustable shock with rezzies.
HiPer Tech carbon fiber rims 9”x9”
ITP mx 18x11x9 tires
Galfer +2 stainless steel brakelines.
Nac Racing Block-off plate (blue)
MOTOR:
Sparks 690 kit:
JE 102, 12.5:1 piston,
Midrange cam,
(2) FCR 35mm Carbs,
HD valve spring kit,
Port &amp; Flow head,
3-angle valve job,
HD clutch kit and
X-6 Stainless Steel header / Spark Arrestor Silencer exhaust system.
Fortin Racing Gears (2nd&amp;3rd)
Billetanium Hydraulic Clutch (blue anodized slave cylinder- mounted at motor)
GYTR billet flange and foam filter setup (no air box lid) with filter cover.
MICS:
Sidewinder Titanium Sprockets front (12t &amp;13t front) (37r rear)
Sidewinder Titanium 520 chain
Tag T2 bars,
Renthal Grip
MotionPro Twist Throttle
A/C front mud screen bumper
A/C rear number plate grabbar
Motion Pro kill switch
DG nerf bars.
Frame - Silvervein Power Coated with Silver Glitter clearcoat
subframe - yamaha blue
Johnny Mac
Aug 15, 2019 03:13 PM
Oct 10, 2015 10:20 AM
MikeyBoyesq
Sep 22, 2015 10:02 AM
essonlaker
Sep 10, 2015 01:12 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
