All Grizzly 660 owner must read.......
#32
#33
2 more pleased Grizzly owners.
Here's more info: Some of the service manual portion of the disk
CHASSIS .................................................. .................................................. 3-39
ADJUSTING THE REAR BRAKE .................................................. ...... 3-39
CHECKING THE BRAKE FLUID LEVEL ............................................. 3-41
CHECKING THE FRONT BRAKE PAD .............................................. 3-43
CHECKING THE REAR BRAKE PAD ................................................. 3-43
CHECKING THE BRAKE HOSE .................................................. ....... 3-43
BLEEDING THE HYDRAULIC BRAKE SYSTEM ............................... 3-44
ADJUSTING THE SELECT LEVER CONTROL CABLE
AND SHIFT ROD .................................................. ........................... 3-46
ADJUSTING THE REAR BRAKE LIGHT SWITCH ............................. 3-47
CHECKING THE FINAL GEAR OIL LEVEL ........................................ 3-48
CHANGING THE FINAL GEAR OIL .................................................. .. 3-48
CHECKING THE DIFFERENTIAL GEAR OIL ..................................... 3-49
CHANGING THE DIFFERENTIAL GEAR OIL .................................... 3-50
CHECKING THE CONSTANT VELOCITY JOINT DUST BOOT ........ 3-51
CHECKING THE STEERING SYSTEM .............................................. 3-51
ADJUSTING THE TOE-IN .................................................. ................. 3-51
ADJUSTING THE FRONT SHOCK ABSORBER ................................ 3-53
ADJUSTING THE REAR SHOCK ABSORBER .................................. 3-54
CHECKING THE TIRE .................................................. ...................... 3-54
CHECKING THE WHEEL .................................................. .................. 3-56
CHECKING AND LUBRICATING THE CABLE ................................... 3-57
LUBRICATING THE LEVERS, PEDAL, ETC. ..................................... 3-57
ELECTRICAL .................................................. ............................................ 3-58
CHECKING THE BATTERY .................................................. .............. 3-58
CHECKING THE FUSE .................................................. ..................... 3-63
ADJUSTING THE HEADLIGHT BEAM ............................................... 3-65
CHANGING THE HEADLIGHT BULB ................................................. 3-65
CHAPTER 4.
ENGINE
ENGINE REMOVAL .................................................. .................................... 4-1
AIR DUCTS, MUFFLER AND EXHAUST PIPE .................................... 4-1
SELECT LEVER UNIT AND COOLANT RESERVOIR ......................... 4-3
HOSES AND LEADS .................................................. ........................... 4-4
ENGINE MOUNTING BOLTS .................................................. ............. 4-5
INSTALLING THE ENGINE .................................................. ................. 4-7
CYLINDER HEAD COVER .................................................. ......................... 4-8
REMOVING THE CYLINDER HEAD COVER ..................................... 4-10
CHECKING THE CYLINDER HEAD COVER ..................................... 4-10
CHECKING THE TAPPET COVER .................................................. ... 4-11
INSTALLING THE CYLINDER HEAD COVER ................................... 4-11
CHAPTER 4.
ENGINE
#34
Could you please let me know what i need to do to get one of the manuals ? cboise@hekimian.com
#36
sounds interesting I downloaded a PDF file 12 megs and its has pretty much everything wish i had of known it would of been so much easier to buy the cd LOL [img]i/expressions/face-icon-small-smile.gif[/img]
#37
Hello Padzz,
I live in Chatham,Ontario & am very interested in buying a cd rom.Could you help me out & let me know where I can buy one & about how much they are worth.Would be greatly appreciated.
Thanks Bob.
e-mail address. serruys@ciaccess.com
Thanks Bob.
#39
yeeeeeeeeees!!!!!!!!!! this is what I've been lookin for please hook me up [img]i/expressions/face-icon-small-smile.gif[/img]
dshumniski@shaw.ca
dshumniski@shaw.ca
#40
