Swingarm mods??
Old Apr 28, 2002 | 03:39 AM
kciH's Avatar
Anyone know of a good shop to lengthen a swingarm?? I only want to know of a shop that you or someone you know have good first hand experience with.
Thanks
Old Apr 29, 2002 | 03:35 PM
Cannitor's Avatar
are you talking about lengthing an existing swingarm or are you interested in purchasing a new one?
Old Apr 30, 2002 | 12:23 AM
kciH's Avatar
I am primarily looking to get the stock swingarm lengthened. I know the longer aftermarker ones are available. I'm just trying to save some cash as I have an extra stock swingarm. I'm looking for a shop to do the work. If you know of someone who sells the aftermarket units at a reasonable price I would appreciate that info too.
Thanks
Old Apr 30, 2002 | 12:26 AM
Ward660R's Avatar
I saw one on e-bay for 250, at the time, But you did have to get a berring carrier. It was new and may still be on there.
Old Apr 30, 2002 | 06:21 PM
Cannitor's Avatar
i would call four stroke tech
i read an article where they lenghthened one on a raptor once
also try james lucky,they sell the part you looking for.
Old May 6, 2002 | 10:54 AM
ANUFSED's Avatar
If you havent noticed the stock swingarm on a 400ex is longer then the Raptor. I have been looking at http://www.speedracingproducts.com/ and the American Star Racing - Swing arms for 499.95. Bearing are included. Also while you are there take a look at Pivot Works rear shock bearing kits. 34.95. Its a good idea to change these when you are changing the geometry of the rear end.
Old May 7, 2002 | 08:05 AM
tom18801's Avatar
send it to any welding shop they can do just as good of a job or better
Old May 7, 2002 | 09:22 AM
raptornz's Avatar
I don't recommend lengthening the stock swingarm. Mine cracked around the right front pivot point where the side rails meet the pivot bearing case, and so did my mates. I got that welded up and lengthened the rear 50mm at the same time. The front cracked again and the rear completely broke off, only holding together by the skid plate. Lucky I didn't kill myself. I ended up getting a LSR plus 1" baja setup. I also cracked the front cross member on that (it was the early square section cross member setup, which has now been superceded with a round front cross member and added gusseting). A tip also is to put 2 needle pivot bearings on each side of the swing arm (helps spread the load) and dump the nylon bearing(total useless). ps Lone star replaced with a new unit. A big thank you there. I've also added 6mm 90 degree grease zerks to the LSR front pivot cases as I ride wet conditions. No moisture in there now destroying the needle bearings.
Andrew
Old May 7, 2002 | 06:23 PM
Ward660R's Avatar
I have cracked mine in the same place twice. I also replaced the nylon bushings with the needle bearings. I am looking for a swingarm but can't quite choak $850 down for a new one. I saw one on e-bay for cheap but it was bad timing for me.
Old May 8, 2002 | 01:57 PM
Jason454's Avatar
Are you guys saying that the main piviot(the one that goes through the rear of the motor) has nylon bushings? Not needle bearings? Ive never taken mine apart. Pretty lame if they are nylon.
