Shock squeaks
Old May 1, 2002 | 11:08 AM
txrideblue's Avatar
The rear shock on my warrior has an extremely loud squeak. I would really like to know some way to lubricate it instead of buying a new one. Any suggestions or comments?
THANKS!!
Old May 1, 2002 | 01:06 PM
GR8T250R's Avatar
Remove the shock and grease the bushings/bearings. If you have a linkage w/zerks grease them to. If you have a linkage w/no zerks, remove it and grease them too. Spray a SMALL amount of lube ( teflon spray, rec.) the shaft.
Old May 1, 2002 | 02:15 PM
txrideblue's Avatar
Thanks for the advice! Do you think it could be the swing arm bearings that I'm hearing instead of the shock??
Old May 5, 2002 | 02:27 PM
skramblr's Avatar
On my bikes, the sqeaking suspension has always been the rubber bushings on the ends of the shocks. A little waterproof grease and the squeek is gone..for the season at least.
Ahtatu
Sep 28, 2015 12:14 PM
cboler9
Sep 24, 2015 08:35 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
bigred20653
Sep 19, 2015 02:11 PM
Canamaniac!
Sep 4, 2015 06:44 PM
