holy tires
Old May 2, 2002 | 11:41 AM
vraptor's Avatar
I have been adding air to one of my front tires every 2 days or so, did not have a tank to put it so I tried the gas leak trick, spray with soapy water, I found 13 holes in my tire, I am guessing cactus spines, small sticks, scorpion stings, rattlesnake bites, c-dales I run over ;-), who knows but that must be a record of some kind, 2 were the most I had ever found in the past
Old May 2, 2002 | 11:52 AM
YamahaRyder's Avatar
Whoa, thats quite a lot of holes. Yeah the same is happening to me, every 2-3 days my tires get really low on air if I don't ride at all in several days. But when I do ride mostly every day, it usualy takes around 5-7 days to go flat.It's very wierd, I'd be thinking Vise-Versa, lol.
Well i'm gonna end up buying new front tires pretty soon cause of leaks and because I have about 1mm thick of tread left, (the Traction SUX on my tires). See ya.
Mike
Old May 2, 2002 | 04:10 PM
crazyBLASTERrider's Avatar
i'v only had one, but it was about the size of a golf ball.
Old May 2, 2002 | 04:24 PM
kuz28's Avatar
Slime.
i'm guessing i have several. but i don't loose air. i usually hear the punture. can't tell until i go to wash the quad later. lime green squirt on the fender tells me Slime saved my **** again.
expensive? absolutely.
damage rims? nope
have i ever been left stranded with a flat? nope
i run it in the trailor tires, my suv tires, pick up tires, mazda 626 tires and of course the warrior(trail machine).i've never had a flat in 5 years.
i do not run slime in my raptors tires though. i use it for MX and although i'm told it will not effect performance i'm not chancing it while jumping. i've had two flats with my Raptor since i've owned it.
Old May 2, 2002 | 05:44 PM
perrya's Avatar
i had the same problem on my old polaris. every 2 days or so the tire would go flat. i knew that the tire was not leaking because i did the soapy water thing. i soon found that it was the valve stem. it had crap clogged in it so i took it off cleaned it and no more flat tires.
as for that slime, good stuff i had it in my warrior when i bought it used and it saved my a$$ a few times!!
Old May 2, 2002 | 05:57 PM
Ward660R's Avatar
I as well use it in my truck tires. The only problem I could see in my Raptor would be the weight. I once heard that three pounds of centrifical weight was equal to one HP. This was on a motor cycle and I don't know how they got the numbers but it makes sense. Not to mention that that would also be unsprung weight.
Sep 30, 2015 01:37 AM
Ahtatu
Sep 28, 2015 12:14 PM
PinkFloydEffect
Sep 25, 2015 06:31 PM
cboler9
Sep 24, 2015 08:35 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
