lost Raptor igntion key..NOW WHAT?!
Old May 7, 2002 | 11:42 AM
joeyd's Avatar
I lost my keys!!!!! Is there any way aorund that stupid key igntion? has anyone disconnectd it? I need to go ridng this weekend
THANKS IN ADVANCE
Old May 7, 2002 | 12:06 PM
THEMOOSE's Avatar
You lost both of them? Damn joeyd!
I haven't tried to bypass the switch so I cant help there. If you take the number off the ignition switch Yamaha can order you another one. I've never seen motorcycle/ATV keys at a locksmith.
Old May 7, 2002 | 12:32 PM
joeyd's Avatar
Yah i know tell me about it.....
Im starting to think that my wife is hiding them on me.....lost the first one a while ago..now this one
LOLOL
Old May 7, 2002 | 12:47 PM
vraptor's Avatar
the yam dealer you got if from might have the key number on file and be able to get you a new one
Old May 7, 2002 | 03:29 PM
bombthreat187's Avatar
good job joeyd ..lol i did the same thing about 2 hours before leaving for upstate . if you pull you ignition switch out and bring it to a locksmith or your yamaha dealer they will have no problem making a copy . i did the same thing and thanks good bomb make the ignitions trackable like yamaha does . i think it cost my 24 $ for the first key and 3 bucks for any other i got 5 that time ..lol
good luck .
and let me know where you going riding AT ??
Old May 7, 2002 | 03:32 PM
lonestarbanshee's Avatar
Get the serial number off your frame, and take it to the dealer. They'll make you another. I lost the keys to a Honda TRX300 once, and had to do that.
Old May 7, 2002 | 03:42 PM
biggerisbetter's Avatar
The Ignition(key)is basically a toggle switch, So put a "regular" Toggle switch in its place. And GO RIDING![img]i/expressions/face-icon-small-smile.gif[/img][img]i/expressions/face-icon-small-happy.gif[/img].
Biggerisbetter.
Old May 7, 2002 | 06:12 PM
Ward660R's Avatar
I always use a screw driver. If it doesn't work the first time just smack it real hard with a big hammer.
If you have another Yamaha try its key, many of them are the same. My warrior key also cranked my buds if you wiggled it a little.
Old May 7, 2002 | 11:02 PM
KNOWSALOT's Avatar
The Facility
Not all dealers have the equipment to make keys because it costs alot of moey to get set up.
We cut keys for $8.00 each for any Yamaha,Honda,Suzuki, and Cannondale.[Kawasaki's code system is screwed up royally]
All that is needed is the code number from the ignition switch. It is stamped on the side of the plastic ignition switch itself.
Keys cannot be made from the serial numbers unless the quad was purchased from that dealer who has the key code on file.
Just write down the code, or better yet take the ignition to a dealer who has the machine to cut the keys.
Old May 7, 2002 | 11:07 PM
Fendercover's Avatar
went to oklahoma and my brother in law forgot his sons key back in missouri, i reached up under the plastic and removed the two wires on the switch and jumpered them together. he rode like that all weekend, you just have to remember to unhook them when your done riding so the battery does not drain down.
bmxatv10
Oct 14, 2022 06:23 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
black_thunder
Sep 6, 2015 04:41 PM
