Raptor shocks and other....
Old May 20, 2002 | 09:36 PM
Sandgod's Avatar
Fourlix knows Works shocks better then Works. Take his advise.......
Old May 20, 2002 | 09:55 PM
Bartman's Avatar
griffbambino, how do you like your Pro Design shifter? Did you get one that works? I heard they had a few probs with the first set. How do you know if you're gettin' the right one or not? My Yammie shop has one down there and I'm thinkin' pretty hard about gettin it. I'm just not sure it's the new one or not. Also, does it help with the shifting? Is it better shifting or harder? thanks, Bartman
Old May 21, 2002 | 01:46 AM
RODSQUADS's Avatar
02raptorboy the TCS zero preload shocks worked great on a couple of my Raptors.They cost a little more than you wanted to spend but they're worth it.They help the quad sit lower and are much firmer, which will keep the tippy feeling OUT OF THERE and give the Raptor much better handling.CT Racing sold them to me I sold them to 14mins when spring cleaning out my Raptors for CRF450r.
Old May 21, 2002 | 03:16 PM
Cannitor's Avatar
fourlix, how much travel will the steelers with the dual rates have?
the rear rebuild on the raptor...does it add additional travel to the stock shock?or zero preload capabilities?
thanks for the info...
Old May 21, 2002 | 11:22 PM
  #15
Turbo33's Avatar
Dido on the TCS for a much better ride and control issue. Lowering with the TCS will make your Raptor corner and handle like a pro bike.You will find with the proper shocks you won't rail or wheelie as bad. You can call Lagacy ATV or OUTTA CONTROL RACING they can get you hooked up at a fair price. Outta Controls Email is outtacontrol33@yahoo.com
Lagacy ATV number is 336-869-4900
Old May 22, 2002 | 11:03 AM
  #16
Griffbambino's Avatar
I like it but it is not of the build quality you would expect from Roll Design. After tightening the thing down with the screw there is still a significant amount of slop(side to side and up and down). It took awhile to get use to it but I got use to the thing. I found a position to put it where I can shift comfortably with my riding boots. It works better than the stock linkage system but for the money it's a rip off.
bmxatv10
Oct 14, 2022 06:23 PM
cboler9
Sep 24, 2015 08:35 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 12, 2015 09:39 AM
