15 tooth sprocket for Raptor
Old May 21, 2002 | 10:29 AM
garyc660R's Avatar
Anyone tried one on an '01? I have been running a 14 tooth front sprocket for a long time and like the results. Continually find myself in 4th and 5th gear on the trail as well and stay away from the 4X4 rock crawling.
Old May 21, 2002 | 11:45 PM
Big55Sexy660R's Avatar
I haven't tried 15 tooth put i tried the 14 and i lost a lot of low end i couldn't hole shot in second gear anymore put i had alot of top end i clock my bike at 79mph with 14 tooth. so want i am trying 2 say is with 15 tooth you will get a ton of top end but you will lose alot of low end. If you do it clock your bike and let me know how fast it goes.Good luck.
Old May 22, 2002 | 12:39 AM
Radman's Avatar
Big55Sexy660R how did you clock your Raptor. I'm also using a 14 on the front, I find that I have that little extra in 2nd for long hill climbs. Before 3rd was to much and 2nd not enough.
Old May 22, 2002 | 09:12 AM
garyc660R's Avatar
I was clocked at 79.3 with the 14 tooth front sprocket. This was with the stock muffler uncorked. I would be surprised if I pulled 1-2 mph more when I hit 5th....I imagine I could pull the same top speed with a 13 tooth front sprocket since the machine could "pull" the gearing better.
That should change now since I have the E-series 99% dialed in perfect. Gonna try a 15 tooth....probably would'nt any be faster on top than the 14 tooth now.....hoping for better acceleration.
Old May 22, 2002 | 10:53 PM
What up Radman I clock my Raptor with my buddy street bike.I didn't like the 14tooth because i ride alot of tight trails so i change it now i am running a 13f/42r bigger tire(22'xct) in the back so now i have a prefect combo great low mid and top end.going clock again this week end just 2 see how close i am with the top end i had before. ? is went do you really need the top end?Where i ride really never use it.
bmxatv10
Oct 14, 2022 06:23 PM
buddieboy
Dec 9, 2016 05:50 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
