Warrior spring preload adjustment
Old May 21, 2002 | 08:13 PM
perrya's Avatar
i'm having some trouble adjusting my front shocks.
The manual says all i have to do is turn the adjuster in a certain way to stiffen the suspension.
Is that all i have to do? because i tried it and it is a little tough to turn. If i put a pipe wrench to it that would ruin the chrome finish.
does any one have some advice, do i just try as hard as i can with a pipe wrench?
thanks for any info!!
Old May 21, 2002 | 08:50 PM
grademan's Avatar
What you need is a spanner wrench. It's made especially for those teeth on your shocks. Check Dennis Kirk, they have pictures of them so you can see what I'm talking about. It's pretty much a "must have" for any atv-er.
Old May 21, 2002 | 08:54 PM
perrya's Avatar
so all i have to do is turn the adjuster and i should be all set??
There is nothing special i have to do?
Old May 21, 2002 | 09:21 PM
grademan's Avatar
Let me give you this link, it is very helpful with shock adjustments.
http://off-road.com/atv/suspension/shockadj.htm
You need to keep in mind your "ride height sag" when adjusting preload.
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
Stever6368
Aug 16, 2015 07:34 PM
manuelrivera
Aug 8, 2015 04:34 PM
suzukiquadrunner1987
Aug 6, 2015 05:29 PM
