Raptor K&N leaking dirt
When I pulled the air box lid off of my Raptor, I noticed a lot of sand had accumulated along the top and bottom edges next to where it is supposed to be sealed. It had worked it's way under the Outerware also. I could see a small area that did not seal very well with the gasket supplied by K&N. After removing the air box and filter to clean it, I found that sand had gotten past the seal and was in both boots leading to the carbs. Not sure what to do to seal it properly. Just noticed in the Rocky Mountain ATV catalogue that K&N makes a sealing grease. Sounds like it might work on the top but how are you goinig to seal the sides and bottom? I need some ideas or other alternatives.
That sux.
I would take the flange off the airbox and check the rubber gasket for damage. Maybe it cam out of the groove when you installed it. Upon reinstalling use bearing grease or other similar grease and put grease all along the rubber seal then reinstall it. Make sure the bottom is in the groove where the stock filter would sit and bolt it up tight. Unless your box is warped or somthing I can't see why it would be leaking by. Have you checked the filter for holes in the fiber or wire on the outside?
Raptorrider2001, you need to run the two stage foam element filter to be safe from pro flow like 14mins and chris run on their raptors. I run a different kind ( UNI dual element). The K&N does have some problems and I would not ever run them in the sand even with the outerware. A lot of people sware by them and get good performance but at what cost for a leak? Not enough difference in performance. They are great for street use.
you should have received a tube of grease with your filter its still a kluge to get it to seat right, pro-design is the best way to go, and paper flows so much better than foam, makes a noticeable improvement in performance, never had had any sand/dust blow by my k&n prodesign and i ride in very dusty conditions, I would only use foam if I was getting in the "wet", not very likely out here in NM
One thing about the Pro-Design filter flange is that it can leak dirt too. It has the thin o-ring that is supposed to seal it to the airbox but I never got a warm-fuzzy from that. I used silicone sealant between the flange and airbox to make sure nothing was getting in.
If you are getting sand between the outerwear and the filter you can wrape some electrical tape around where the elastic part of the outerwear is??? I've done that in the past but even when I haven't I rarely get any sand past the outerwear.
This is all on a Banshee BTW but I think it applies fo rthe Raptor as well.
