Raptor Axle?
Old May 23, 2002 | 09:58 PM
Radman's Avatar
I have an 01 Raptor and want to do some maintenance to the axle and swing arm. So I read the manual and taking thing apart is simple. Now what I would like to know is what is everyone using to reassemble the 50 mm locking nuts for the axle? Did you buy the tool from Yamaha, and if so how much does it cost? Or did you just wing it? TIA
Old May 23, 2002 | 10:49 PM
Thrust's Avatar
Gee,thats a tough one,I wouldn't wing it.But it's spelled Axle not "axel"
Old May 23, 2002 | 11:44 PM
Radman's Avatar
Happy!, thanks for your help, this will get me back on the road.
Old May 23, 2002 | 11:57 PM
ptlm3's Avatar
Radman, when I changed my stock axle to a Durablue I went to TSC (Tractor Supply Company) and picked up an 18 inch adjustable cresent wrench for $30.00. It opens to 58mm which is more than wide enough for a stock axle nut and just wide enough for a Durablue locking nut. It's also long enough to give you enough torque, so there's no need to put a pipe on the end of it. Hope this helps you out.
Old May 24, 2002 | 01:27 PM
FISHER1648's Avatar
Motion Pro makes a nice set of wrenches (2 wrenches) for this. They are made for a 1/2' drive socket wrench handle / breaker bar. If I recall correctly I paid $36 bucks at the shop - mail order might be cheaper.
Old May 28, 2002 | 05:26 PM
FourStrokeFan's Avatar
I got an 18" adjustable wrench from JC Whitney for $17 and a 2" combination wrench for $9 at the local junk tools place. They worked perfectly for the job.
Old May 28, 2002 | 06:35 PM
NotuRaptor2's Avatar
I have the Motion Pro's and they are worth the investment. Even with the 2002 axle setup on my 2001 Raptor, I still have to tighten the axle nuts every 20-30 hours of riding.
I had a lot of trouble ordering them through a local distributor so I got them sent directly from Motion Pro. If you want them immediately, this is the route I would go. Tell them your local supplier said they were on backorder or something from their supplier. They will want to keep you happy and will send them right out to you.
The only downside to the adjustable wrenches is not knowing how much torque you are putting on the axle nuts.
/NotuRaptor
bmxatv10
Oct 14, 2022 06:23 PM
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
