Rev limiter on Shee?
Old May 27, 2002 | 03:20 AM
Thrust's Avatar
I was just wondering,does the banshee have a rev limiter in 6th gear at top speed? I mean stock.
Old May 27, 2002 | 05:27 PM
smitty911's Avatar
Yup, It's called lack of Horsepower.LOL
Most quad with stock HP won't come anywhere near the Rev. Limiter in top gear.
Smitty
Old May 27, 2002 | 06:52 PM
Imback's Avatar
The type of pipes you are running on your Shee will determine how high it will rev.Do not try to find a rev limiter there is none unless you consider the parking brake switch to be one...
Old May 28, 2002 | 12:24 AM
Thrust's Avatar
I don't think yall understand,I mean something that stops the engine from trying to accelerate anymore in the last gear at top speed like 75. You know,something that keeps me from floating the valves!
Old May 28, 2002 | 12:36 AM
Radman's Avatar
2 stroke, the only thing from limiting the revs is air flow (and piston speed). In and out (or up and down). The reed valves work totally different than on valves on a 4 stroke. As the piston goes up it draws air into the crankcase opening up the reed valves. As the piston goes down it is creating pressure in the crankcase forcing the reed valves closed and pushing the air in to the combustion chamber. So like smitty911 said your stock machine will not have enough HP to pull max rpm's in 6th gear. Hope this helps.
Old May 28, 2002 | 09:14 PM
Thrust's Avatar
So,you're saying I could hold it wide open full throttle in 6th gear going 75 and it not screw anything up?
Old May 28, 2002 | 11:39 PM
Thrust's Avatar
I guess nobody has gotten their banshee up to 75 and kept it at full throttle.....
Old May 28, 2002 | 11:53 PM
ltracerx's Avatar
Thrust, your confised I think. A rev limiter has nothing to do with valves, all it is a "something(I hate elcetronic stuff[img]i/expressions/face-icon-small-smile.gif[/img])" in the CDI unit that stops an engine from revving past XXXX RPM. And it doesn't just apply to 6th gear!
Old May 29, 2002 | 12:21 AM
Thrust's Avatar
Yeah man,thats what I mean does it have that in 6th gear?
Old May 29, 2002 | 12:34 AM
Thrust's Avatar
Nevermind forget it I understand now. *It does Jacob in EVERY GEAR!!*
Shutup brain,or I'll stab you with a q-tip! *Oh no not that!!*
