Short 02 Grizz valve adjustment / jetting Question.
Old May 28, 2002 | 11:18 PM
Lsnake68I's Avatar
I was thinking about doing the stock muffler modifacation to my 02 grizz and am planing everything out ahead of time. I have the CD for the grizz and understand it pretty well, accept for a couple of things.
1) It says 0.1- 0.15mm (intake) & 0.15- 0.2mm (exhaust) for the clearence. which side of the scale should i aim for? will one side make it faster or slower?
2) you adjust one at a time right? i take it you can tell the diffrnece between the intake and exhaust ones.
Old May 28, 2002 | 11:32 PM
Jack's Avatar
Seriously, your question #3) tells me you should not do anything. Take it to someone who is experienced.
Old May 28, 2002 | 11:34 PM
boneylong's Avatar
if you want it to continue running leave it alone!!take it to a dealer.
Old May 29, 2002 | 03:54 PM
Lsnake68I's Avatar
sorry, i ment what is the diffrence between adjsting the valves and jetting. i know jetting is adjusting the air/fuel mixture, what does adjusting the valves do exacly? is it hard to jet it? i personaly don't have the right tools but i can take it to my friends house. does is say how to do it on the cd, i have not found it yet. I don't have to adjust the valves when i do he muffler right, just the jetting?
Old May 29, 2002 | 04:00 PM
NHGrizzly's Avatar
I agree with these guys. If you can't answer these questions, then you are probably going to due more damage than good.
>>1) It says 0.1- 0.15mm (intake) & 0.15- 0.2mm (exhaust) for the clearance. which side >>of the scale should i aim for? will one side make it faster or slower?
Split the difference! If you can get the clearance within .05 mm, then you should be happy with that. Thats close to RCH...Don’t forget TDC.
>>2) Isn't there more than one valve, it only says how to adjust one. unless the one >>adjustment does them all.
The Grizz 660 has 5 valves. (OH NO!! is 2 intake..and 3 exhaust ..or 3 intake and 2 exhaust...maybe its 2 and 2 with a spare?)
>>3) is adjusting the valves and jetting the same thing?
Valves are in the Engine... Jets are in the carb. Unless its a Jet engine! (Then thats totally different [img]i/expressions/face-icon-small-smile.gif[/img]
But all kidding aside. Leave it to the pros. The machine is too expensive to learn or play with. Find a little lawn mower engine and tear that apart.
Old May 29, 2002 | 08:41 PM
perrya's Avatar
Man
and everyone says i don't know anything!!
Did you just copy those long words and numbers out of your manual and hope someone could tell you what they all mean??
JK
!!Caution!!
this is just a joke.
try laughing.
(not to be taken offensively)
I know how you are Lsnake.
Old May 29, 2002 | 10:44 PM
mich660griz's Avatar
all kidding aside. go into the cd, and look under the manual. click on the manual, and scroll down to section 3 i think, and find valve adjustments. print out all 3 pages, and make sure you understand them before you even touch it!!! if you feel you understand it completly, then go get you some feeler gaiges, and you will see the gauge numbers on them. if you have read everything thourghly, and you are mechanical at all, you can do this. you dont need to take off the front clip, but you do have to remove the front rack, gas tank, side panels, seat, and get clearance. there are 5 valves, 3 on top, under the flat cover are intake, and 2 in front, under the 2 round covers, are exhaust. you will need 2 pairs of needlnose pliers, and alot of paintance. for under $200.00 a shop will do it for ya, but if you read real good, and take your time, you can do this!!! good luck!!!
my pictures
Old May 29, 2002 | 11:08 PM
Lsnake68I's Avatar
come on i know that where the damn things are located, i'm not a total idiot. [img]i/expressions/face-icon-small-mad.gif[/img]. what i wanted to know was what the two do besides what i said before. do i need to adjust the valves after modifying the muffler, where does is say how to jet it on the cd.
P.S. Perrya how many tmes do i have to tell you to leave my threads alone. I DON"T LIKE YOU. yeah i copied two sets of numbers you idiot, real hard to read and understand.
Old May 30, 2002 | 12:14 AM
PADZZ's Avatar
You don't have to adjust the valves when jetting. Not sure what size the main jet is, just go up one size per mod (K&N, exhaust etc.). Jetting the carb is quite simple. Hardest part is removing the plastic. Good luck!
slowgsxr97
Mar 18, 2022 03:40 AM
bpegram84
Jul 22, 2015 08:15 AM
bpegram84
Jul 22, 2015 08:12 AM
Aitch
Jul 21, 2015 09:40 PM
toonces
Jul 16, 2015 03:19 PM
