Leaky tire
Old May 29, 2002 | 08:44 PM
Ward660R's Avatar
I have a set of 20x10x10 Sand Sharks that lose air fast. It comes from around the bead. How can I make it seal off? I have tried tearing them down and cleaning them out and that didn't work. Any opinons would be helpful to keep me from buying new tires and rims.
Old May 29, 2002 | 09:48 PM
TG1's Avatar
TG1
There's some stuff call green slime (I THINK) Wal-Mart sells it. This product is supposed to seal and reduce punctures although I have never used it. A couple of tires on my Cat leak air slowly so I've been thinking of trying the Slime. Except it costs $17 buck a pop and it takes a container a tire. Highlifter sells Air Lock Tire Sealant:
http://www.highlifter.com/store/Air-...e-Sealant.html
Hope this helps.[img]i/expressions/face-icon-small-smile.gif[/img]
Old May 29, 2002 | 10:34 PM
thrshr's Avatar
make sure there's no pits or rust on the bead of the tire. if it looks okay, check the rim to see if it's bent or dented. also, make sure it's the right size tire for the wheel.
Old May 29, 2002 | 10:49 PM
THEMOOSE's Avatar
Tire shops have this stuff called bead sealer.
after you do what thrshr said put some on your beads.
Old May 30, 2002 | 12:41 AM
Ward660R's Avatar
Thanks for the help guys. They are on aluminum so rust is out of the question. They are dented but that isn't where the leak is comming from. I still don't understand why I bought .125s in the first place. I will have to try the bead sealer.
Sep 30, 2015 01:37 AM
Ahtatu
Sep 28, 2015 12:14 PM
PinkFloydEffect
Sep 25, 2015 06:31 PM
cboler9
Sep 24, 2015 08:35 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
