My Raptor feels a little Tippy, is that normal?
Put a wider axle on. Put a wider axle on. Put a wider axle on.
Once the rear is widened, problem solved. Widening the front is cool too, but a bunch more dough. With the rear widened you can live with the stock front width no problem. Wheel spacers or offset rims in front screw up the steering geometry. Wheel spacers in back are okay if you don't jump...[img]i/expressions/face-icon-small-cool.gif[/img]
You can try wheel spacers. If you reverse the front wheels the valve stem hits the caliper. If I had some cheap rims I would like to weld the stock valve hole closed and place it on the other side(reversing the rim). This makes it about 2" wider each. Just an idea. Anyone want to donate a couple of rims[img]i/expressions/face-icon-small-happy.gif[/img]
Wheel spacers are the ticket for us poor folk. [img]i/expressions/face-icon-small-smile.gif[/img] My 1" offset front rims widened my front to 47 1/2". I've had no ill affect in handling because of it. I jump some, 3-4' off the ground 10-20' long and have had no problems with my rear axle.
Radman,
You can reverse your wheels without permanently fixing them in the reverse mode.
Drill another hole on the other side of your wheels for a new valve stem. Install valve stem correctly as you would on any wheel. At this point you have two valve stems sticking out of the wheels. One on each side.
Remove the valve stem on the other side [stock location] and put a NEW valve stem in upside down. This will leave the long part pointing inside of the tire. Then take a dremel tool or small grinder and grind away just over an 1/8" from the valve stem butt that now sticks outside of the wheel. Put it back on the hub and tighten it down. Look behind the wheel. It should now clear your brake caliper. If not, grind away a bit more from the stem butt.
It may sound like something thrown together, but by doing this, if you ever want to go back to stock offset in the future, you just swap locations of the valve stems.
Oh great now you've gone and blown it for me, now nobody is going to donate 2 rims for my test!
I guess I'll go and buy some valve stems.[img]i/expressions/face-icon-small-sad.gif[/img]
KNOWSALOT, do you think the valve holes should be 180 deg's on the other side to help with the balance of the rim. Or it won't matter? (you know one on the inside and one on the outside, one on the top and one on the bottom)
