Torn inner cv boot on 02 grizzly agian again again.....
My buddy tore his inner cv boot again, this is his third time. He has a lift on it and has Highlifter cv guards on it also. It rips at the rib closes to the diff. I think it has to do with the Lift. has anyone eles had this problem? He likes the lift cause it stiffen his front end up. He don't like it to sage when he puts on the brakes. With the lift its stiff. Any repleys would be helpful.
The right rear inner c/v boot by the diff. on my new 02 Grizzly ripped,, had about 150 miles on it at the time.. Had stock tires on it at the time...A stick may have poked it ?? I found that Advanced auto parts sells car halfshaft "split" boots that fit perfectly over the stock boots for added protection..I also put zip-ties around the new boot and in the ribs to keep it from coming apart ans applied black oil pan silicone to the seam to watertighten it..I am putting them over all 8 boots,, they are a lot tougher than yamaha boots..I also have aluminum c/v guards but when U go in deep mud/waterholes rocks and sticks settle on the bottom of them right under the c/v boots and hitting a bump can send that debris up and into the axles..
I agree – Most likely the added angle is stretching the boot. The OEM is to thin and expensive ($50 per boot kit). An Automotive boot is so much thicker ($12 per boot kit). I haven’t been able to find a automotive replacement boot and I have done a lot of looking. The closest I came is a 83 Honda Civic inner boot. Still a little large – about 10mm. I am going to try a shrink it with a heat gun.
I tore both my front outboard cv boots on my 650 due to some really nasty mud with long beargrass in it. The grass was wound so tight around the front axles that my one front boot was twisted four times. I replaced the boots with stock replacement boots, no problem. Anyways, I was on these forums and was informed by somebody that they make a Kevlar cv boot cover. Too bad they don't make Kevlar cv boots!! I don't know who makes them, but they are out there.
