Raptor reverse?
Old Jun 17, 2002 | 01:02 AM
THEMOOSE's Avatar
Mine only grinded once then i figured out how to do it. You can hear the gear engage if you don't hear it stab it again.
I thought about taking it in under warrenty for an adjustment but since I figured it out I didn't bother. Besides, I don't want any one working on my quad but me.
Old Jun 17, 2002 | 02:51 AM
Raptoryfn660r's Avatar
RIP Dear Friend
themoose says it right.
Quote, I don't want any one working on my quad but me.
Chet[img]i/expressions/face-icon-small-cool.gif[/img]
Old Jun 17, 2002 | 02:56 AM
rob660's Avatar
Thanks for the info guys. sounds like most of them are doing it so i know it not just mine. I just wanted to make sure there wasn't something wrong with it.
Old Jun 17, 2002 | 11:43 AM
2fiftyX's Avatar
Good post! I figured it out too but I'm glad to see that I'm not the only one that doesn't fully engage reverse sometimes.
I always slip the clutch a little and shift down while listing for the gear to engage and I'm good.
I wonder if a new Hinson Clutch basket and clutch plates will make a difference?
Old Jun 18, 2002 | 02:31 AM
  #15
scottd's Avatar
Have you guys tried adjusting the cable freeplay from the **** to the lever on the side of the engine case? Maybe there's too much slack in it and it's not fully releasing the mechanism. Just a thought.
Old Jun 18, 2002 | 06:55 AM
  #16
kingron's Avatar
My LE doesn't do it. So far perfect shifting, up, dowm or reverse.
Old Jun 18, 2002 | 09:53 AM
  #17
warrior007's Avatar
<< Have you guys tried adjusting the cable freeplay from the **** to the lever on the side of the engine case? Maybe there's too much slack in it and it's not fully releasing the mechanism. Just a thought. >>
I think its just an interlock that wont let you go down past 1st, if your getting past it then it doesnt need adjusted or it wont help. I think the problem is pretty common, and have seen it on all the quads I owned. it can get better or worse depending on how your clutch is adjusted and mine has done it, slip the clutch a little when your putting it in.
bmxatv10
Oct 14, 2022 06:23 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
