Raptor Chain Noise
Old Jun 25, 2002 | 04:55 PM
Sport400LSC's Avatar
I adjusted my chain for the first time yesterday.I followed the manual instructions and the chain has about an inch or so of play.I am hearing a whinning noise as the chain goes around the sprocket ( front it sounds like). Is this normal?
This is the first time I have adjusted the chain.It seemed to be pretty loose before I did.I have about 10 hrs on my Raptor.I did not hear this prior to adjusting it.
Thanks,
J. Prentice
Old Jun 25, 2002 | 06:09 PM
dooboarder's Avatar
yamaha's tension spec is too tight. Loosen it and see if the noise goes away.
If you don't you'll not only have a noise, but you'll break the chain if you take any big jumps.
Old Jun 25, 2002 | 06:46 PM
Ward660R's Avatar
Also make sure that all the weight is on it when checking the tension. I have met some people that didn't know this.
bvolks
Sep 13, 2015 12:57 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 11, 2015 11:42 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
bmark0610
Sep 7, 2015 09:42 PM
