hey 14mins
Old Jul 3, 2002 | 12:10 AM
desracers's Avatar
Say where the result of the dyno that you had from last weekend? As you mention from other fourms
Just asking.....
Thanks.
Bill
Old Jul 4, 2002 | 03:19 AM
14mins's Avatar
These nubers were low but consistent so...........
1. DS760- 52hp,38.7 torque
2. DS650- hi-comp piston,stage 2 cams alky- 45.3hp, 39T
3. 660Raptor-full ct exhaust, airbox open 38.8hp 37.7 T
4. DS650- Jetted? Stock exhaust 44.8hp, 37.5 T
5 686- Gyrt slip-on 42.7hp 39.5T
6. Banshee- Toomey T-5 stage 4 carb 33.5hp 23.4 T
7. Raptor- T-4 36.3hp 34.8 T
8. Stock raptor 33.8 hp 31.5 T
9. Raptor- jetted Fmf pipe 31.4 hp 35.9 T
10.Drag Banshee- 59.5 hp 35.2 T
11.Raptor CT full exhaust jetted airbox open 36.9hp 33.1 T
12 Raptor gutted factory pipe 37.5hp 36.6 T
13
I have the charts and names, but the dyno guy did not list the modds on all of them[img]i/expressions/face-icon-small-sad.gif[/img] I can post more but some i do not know if it is a raptor or DS for sure. These are just a general idea. I think i have 30 dyno charts.
Old Jul 4, 2002 | 10:16 AM
desracers's Avatar
Thanks 14mins
Boy sure those numbers are low. Was the dyno running right or due to the dyno operator running it? Just asking.
Thank again
Old Jul 4, 2002 | 01:07 PM
THEMOOSE's Avatar
The Stock Raptor seems to be about right but I agree the modified quads seem low.
I got better HP numbers than that with my Sparks X6 & Dynojets & I used an automotive Dynojet.
I'm guessing the guy doesn't know how to run the dyno correctly yet, either that or the FMF pipe sucks on a Raptor (2.4 HP less than stock!)!! You'd think with all the pulls this guy made he'd at least used it for practice & tried to do every thing the same way on every pull.
Make him practice his setup 14mins & maybe next year a DS with high compression piston, stage 2 cam on alky will make more than 1/2 HP more than a Jetted? DS with a stock pipe!! See if he can take a quad off & on the dyno 2 or more times on the same day & get the same numbers. Then have him put the same quad on another day with diffrent weather conditions & see if you can get the same numbers.
Unfortunatly despite all of 14mins hard work I don't think these dyno numbers are of much use[img]i/expressions/face-icon-small-sad.gif[/img].
Old Jul 5, 2002 | 12:13 AM
14mins's Avatar
Sorry guys. We did get the fuel/air ratios. That was all i was really looking for. It would have been nice to get a monster hp number to frame by the canceled check for the modifications. lol
Old Jul 5, 2002 | 01:52 AM
Ward660R's Avatar
Well I'll tell you from expereince that the FMF sucks. I have one and dislike it alot. No I have never made any dyno runs but I hear of 45+ with a pipe and jets and I don't think that I am near that. When I first put it on it actualy took away from the top end. I could race a stock banshee on the road, when the Raptor was stock, and would win all the way. When I put the pipe, filter (Pro Design), and jets in I would pull hard at first then after a LONG stretch he would start to gain ground back. So if you are looking for bottom end its good, I guess, but on the top end no way.
Those # do sound a little fishy. Here it saying, if my math is right, that the 686 is only making about 21% more than stock. From other people on here it has been said about 45% more than stock. My math is kind of rusty, you know what you don't use you lose.
Old Jul 5, 2002 | 06:05 PM
ZRWHAT's Avatar
14mins & THEMOOSE: These numbers sound right online with the dyno that I ran my raptor on. The piped/jetted/intaked raptors were only pulling 3-5hp more than stock. My 686 was around 10hp more than any other raptor tested (the closest was a high comp piston'd/cam'd/pipe'd/intake'd @ 39hp) on the same dyno with the same dyno operator Dyno Results, but that doesn't explain why I am still over 10hp off the claimed hp of the performance shops 686's? As for torque, I was also on track with just over 42 ft-lbs Dyno Torque Results. Just my $.02.
Old Jul 6, 2002 | 12:11 PM
14mins's Avatar
Once i get mine dialed in above 50 hp, i will be happy. Going to make a piston/cam change. 16hp over stock is a heck of a improvement across the board. I have come to the conclusion there are not a lot of 50hp plus machines running around. Cause i have run hundreds of modded machines with great success.
shmee
Jan 1, 2005 02:31 PM
Hurycne
Dec 17, 2002 07:19 PM
Zombie66or
Nov 19, 2002 08:00 AM
14mins
Nov 13, 2002 02:40 PM
layjzay
Sep 27, 2002 11:19 AM
