engine troubles!!!!!!!!
Old Jul 10, 2002 | 12:47 AM
reconbasher's Avatar
what is a sign of me needing to rebuild my blaster 2 stroke motor? it has 150 Lbs. of compression like the clymer manual recomends, runs great still, but its a pain in the A** to crank when its cold. I have to pull it off to crank it.
I've put a new spark plug in it too. figured it might have fouled out. I mix my gas 32:1 ratio.
Old Jul 11, 2002 | 01:59 PM
AlkyBurninX's Avatar
How old are those reeds? If they have quite a bit of time on them, you might try flipping them over or buying new ones. One might also be broken.
If the piston has been in a while, it might need a new one. 2-stokes are bad about wearing the rings thin.
Does it idle right or does it rev up after sitting at idle for a few seconds. If it revs up, you have an air leak.
One last simple thing, check the air filter.
Let me know if any of this helps.
manuelrivera
Aug 8, 2015 04:34 PM
cornermike
Jul 30, 2015 06:37 AM
heath legg
Jul 24, 2015 01:01 PM
ltrmc02
Jul 22, 2015 04:50 AM
Desimation2k8
Jul 17, 2015 12:37 AM
