Bear Tracker Tires
Old Jul 23, 2002 | 05:57 PM
xermat's Avatar
Greetings from Maine.
Has anyone put larger than stock tires on their Bear Tracker?
I would like to get a little more clearence and traction without
increasing the overall width of the ATV by much. ( It fits perectly
in my truck now.)
Are there any other reasonable performance enhancer.
Thanks for your help.
xermat
Old Feb 12, 2003 | 10:03 PM
crazzybeartracker's Avatar
Default Bear Tracker Tires
i put 22x11x10 Excavator's on my beartracker. if u want a pic of them on it i can send you a pic.
Old Feb 22, 2003 | 03:40 PM
xermat's Avatar
If you've got the time, I wouldn't mind seeing the photo. What size did you put up front?
xermat
cmattss1@maine.rr.com
Old Feb 22, 2003 | 05:14 PM
im still wating to get more cash to get front tires cauz i had to get a crank case gasket and had 2 pay 2 fines from getting caught on the road!!lol stupid me and i gots da get my back breaks fixed and i dont know what i need for that yet so when i get aroung to it ill check on front tire sizes.
Old Sep 18, 2003 | 03:08 PM
doggster's Avatar
I have a 2000 Bear Tracker with 22x11x10 Titan 489 A/t's on the rear. I think that is a little wider than you are looking for. For the front I am going to get 23x7x10s but in the M/T. They are alittle more agressive and will give it a good look. My rear tires are might need to be replaced soon too and I think I might go with the Titan Fast Trekkers. They are a sportier tire and they are really hard so they won't wear much. But they dont come in the 22x10x10. You would have to go with and inch wider 22x11x10. In the Dennis Kirk Catolog there is a company named Duro which makes a 21x10x10 size tire. That wouldnt give you as much ground clearance but you would have more power to the ground because it is easier for the motor to turn the shorter tires. If I were you I would go with and agresive 23 inch tire on the front which will stick to the trail and with the extra inch it will make it handle better. And for the rear go with a 21 or 22 inch because it wont take away your power.
Ean
Dec 19, 2022 08:48 AM
STLyamwar
Jul 25, 2020 04:44 AM
Polaris5
Aug 29, 2015 09:11 PM
Ean
Aug 28, 2015 09:39 AM
austinwhitton
Aug 11, 2015 06:21 PM
