Help with 2 stroke tri-moto 175
Old Aug 1, 2002 | 10:55 PM
goattrotter's Avatar
We have a problem with our 175 and we believe it is in the carburetor and we have no clue on how a 2 stroke carb.. should be adjusted?
It is now idling and seems to run perfect till it starts to rev out "mid throttle" ,any suggestions?
Old Aug 1, 2002 | 11:18 PM
foneguy's Avatar
put the air screw in all the way, then turn it out 1 1/4 turns. clean the air filter try that. it sounds like your not getting enough air. look int the manual if you got one. id check the filter first
Old Aug 1, 2002 | 11:35 PM
Thanks ,we will give it a try and let you know!
Could it have anything to do with spark!
Old Aug 3, 2002 | 10:57 PM
foneguy's Avatar
2 strokes need spark and air/gas mixture to run.....no spark no run. if the timing is off then yes that could be trouble
exmotocrosser
Sep 13, 2019 06:12 AM
exmotocrosser
Sep 26, 2015 08:18 AM
BYC
Sep 25, 2015 02:10 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
