Banshee Mods whats the best bang for the buck?
Old Mar 23, 2000 | 11:32 AM
bash's Avatar
B.K.,
How do the FMF torques compare to the Pro Circuits that your buddy put on his? Do you do woods riding and how hard it is to keep on the pipe with those aftermarket pipes?
Old Mar 23, 2000 | 07:55 PM
BK.FORTUNE's Avatar
Bash,
The PC's are a great woods pipe. I feel that my buddies quad has more low end than mine. The PC's are more for low to mid-range vs. low thru top end like my pipes. It is real easy to stay on the pipe because the throttle response is excellent. Power band is instant with both pipes. I mainly ride in the woods, haven't had any trouble yet. Hope this helps!
Old Mar 23, 2000 | 10:45 PM
blue_banshee's Avatar
here's the scoop on what to do to keep a reliable banshee. the coolheead is a nice product, increasing hp's and decreasing degrees, but if u r gonna install one then add a supercooler by prodesign, only 30$ and will decrease temp even more, and also u need to get a stronger clutch, i ould recommend a hinson basket(210$) and duncan plates, same as yammy fzr1000motorcycle clutch plates, with some stronger springs by duncan,(not too expensive), and some new tires, i cant tell ya what type since i dunno what type of riding u do, i would go with 20cc domes in the coolhead, get a proflo adapter plate for your k&n, portwork is a little costly compared to everything else mentioned, get some reeds, either the v-force or the pyramid rad valves(around 200$) if u do go portwork, LRD and portmagic are good places to go and also CT, C&O can build a nice drag quad. hope i have helped a good deal. good luck
mrtidy
Feb 3, 2016 05:00 PM
Sep 23, 2015 06:23 AM
Ridgebackguy86
Sep 19, 2015 12:48 PM
PrairieDog126
Sep 16, 2015 01:33 PM
1ArmBandit
Sep 8, 2015 08:59 PM
