anyone know about the macdaddy rear shock?
ive got tripple rate works on the front and want to have my stock rear shock reworked,anyone had the macdaddy kit done and know the price?also i am wondering if there are any other options.the biggest complaint i have with the rear is i want it to go through the woops better.
I use it Derby and it is night and day difference. For the price, you can't go wrong. It allows the rear to sit from 1-3" lower depending on your set-up and how the run out is adjusted. You will gain I believe 1-1 1/2" of travel too. I like mine and would do it again, if that makes a difference.
If I remember correct, I think the cost was around $250-$300. For more then twice (some 3X's) as much, you can get a new Elka rear, or other brand name.
Good luck!
Good luck!
