00 Kodiak Speedo & upgrades
Old Mar 21, 2000 | 10:00 AM
gengine's Avatar
Does anyone know if Yamaha is offering a speedometer/odometer as an accesory for the Kodiak? I saw a post where "therock" has added a cateye.com mountain bike computer for this. How does the pick-up mount? Also he has mentioned increasing the size of the main jet from 132.5 to 137.5 Is the Kodiak really that lean from the factory? Mine is very cold blooded which would lead me to believe I also have a lean condition. Any thoughts on this would be greatly appreciated.
Thanks
00 Kodiak 4x4
94 Honda Magna
89 RM250
etc...
Old Mar 21, 2000 | 08:12 PM
ahamay's Avatar
A lean condition means that the combustion temperature is too high. This has nothing to do with your machine being cold blooded. I believe the reason the 2000 Kodiaks are cold blooded is because they have no thermostat.
Old Mar 21, 2000 | 09:03 PM
Jeepers's Avatar
I guess I should notify Yamaha that on page 5-6 of their service manual they made a mistake regarding a thermostat. The manual shows an inspection procedure for one. I drilled out my main jet with a 5/32 drill bit - WOW - what a difference. I also cut off 1 1/2 coils from the carburetor spring and left the clip in the stock position. The pilot screw was turned out 1/2 turn. Stock air box, exhaust, and tires. Plug readings look good. This was done on an 82 degree day in central Arizona. That's not a dust cloud in front of you, that's ME spinning all four wheels. I love this machine
Old Mar 21, 2000 | 10:32 PM
gengine's Avatar
I understand what a lean condition is. It is not getting enough fuel which in turn can raise your head temperature as well as burn holes in pistons etc.... It can also greatly diminish your machines performanceas well as make it seem "cold blooded". The reason I say this is because it takes a long time until you can completely turn off the choke. All the choke does is restrict the amount of air entering the carberator; therefore creating a richer condition than when the choke was off. My logic seems sound but I am open to other suggestions.
Thanks
00 Kodiak 4x4
etc...
Old Mar 24, 2000 | 12:51 AM
therock's Avatar
Yes for sure go up on the jet. I did and WoW. Much better on top.
Gengine, do a search on me "therock" and you should find a good discription of my speedo setup.
If not e-mail me.
Ac
Old Mar 25, 2000 | 01:38 PM
etkimball's Avatar
I just got my speedometer/odometer from Yamaha Thursday. I put it on and went riding Friday, it showed about 52-53 MPH. It dose have a mileage reset but not a mileage counter . All the parts that came with the set up have preexisting mounts, just a way for Yamaha to get more money. It fits real nice where the ignition key goes. You get a new console with dash lights holes to install your old lights in and a hole for the speedometer, ignition key goes on the right. The price was $99.95 + tax = $107.44 Good luck
Old Mar 25, 2000 | 10:33 PM
kyle_400's Avatar
would you happen to have the part # for the speedo? thanks.
Old Mar 26, 2000 | 12:01 AM
etkimball's Avatar
It counts the miles but it has a reset button for the mileage, it dose not retain the mileage accumulated. The part number is YAM 5GH-W0081-00-KT METER it took about 6 monts for them to get it in.
speedbuff
13
Nov 11, 2020 10:16 AM
YankeeRebel
Oct 6, 2015 06:44 AM
jankerstien
Sep 21, 2015 03:09 AM
black_thunder
Sep 20, 2015 10:21 PM
Bonzhonda300ex
Sep 17, 2015 10:44 AM
