Raptor won't start
#21
Mine did the same thing, I was scratching my head for a day or two and found out my valves tightened up on me. Sure ran good until the time I shut it off, but I must tell you that it did have a bit starting like I wanted it to but after the valve adjustment it started up on a slight touch of the button. Let us now what you find out ok.
#23
Greetings from Ocala, FL.... I am by no means a mechanic...but just my 2 cents worth.... Try to check all the little stupid start lockout things...you know if it senses you dont have the clutch pulled in etc...i know on my warrior i had a fit of a time tracing a no start problem and found it in the reverse lever wire. Had something to do with the safety lockout features. I probably didnt explain this very well...maybe someone else could elaborate a little better.
Dave
Dave
#24
Thanks for the replies everyone! I double checked all the wiring for continuity last night and all is good there. I can't really check the CDI as far as I know, maybe somebody has a way..... I will check the valves tomorrow and see how they look. I had checked them 4 days before it stopped working, so I was just bypassing them, but now that RaptorQwner mentioned it, certainly could cause this problem.
#25
#26
#27
<< I stoped to help someone in the dunes who could not start his bike. After 15 minutes of checking things, I turned the fuel valve to reserve and it started right up. Sometimes the solution staring you in the face is the hardest one to see. >>
Man---I wish this was the problem!! I ordered the starter plunger assembly (should be in today) and will install it. It was the only thing I could find wrong, it was pretty corroded. I took the carbs apart and checked for clogs, etc., it all looked fine. Fuel is getting to the carbs. The only other thing I think may be the problem is a faulty CDI.
#28
Just wondering did u ever check the compression by chance????
just an idea, but i thought u had fire so that means ur cdi is technicly good. just some thoughts
Eshelman
88 Warrior
K&N Air Filter
No Airbox
Pro Circuit T-4
Duro Rear Tires
DP Race Brake Pads
Fresh Rebuild
DG Nerfs W/ Red Web
Plastic Redone
99 Blaster
Fatty Gold Series Pipe
Power Core 2 Silencer
Eshelman
88 Warrior
K&N Air Filter
No Airbox
Pro Circuit T-4
Duro Rear Tires
DP Race Brake Pads
Fresh Rebuild
DG Nerfs W/ Red Web
Plastic Redone
99 Blaster
#29
#30
Sorry about that desracers--compression is fine! I took the carb apart a little bit ago and found something I had missed on the first try; the needle valve set (under the float attachment) on the left carb was stuck. It didn't allow any fuel in. I didn't catch it at first because there was fuel in both bowls when I drained them. The second time I drained the carbs, there was no fuel in the left side, which was strange, so I just took it apart and found it. Started right up! Thanks for all the help everyone! [img]i/expressions/face-icon-small-happy.gif[/img]
