Adjusting valves on '02 Grizzly
Old Aug 27, 2002 | 06:21 PM
AUGER's Avatar
I purchased a new '02 Grizzly 2 weeks ago. I've noticed on this message board that frequent adjustment of the valves is necessary. What is involved in adjusting the valves? What kind of tools are necessary? Is it difficult or is it just time consuming? Thanks for any replies in advance.
AUGER
Old Aug 27, 2002 | 09:11 PM
mich660griz's Avatar
auger. with the manual, or better yet, the c.d. it isn't too bad.
tools needed. screwdrivers, a set of metric sockets, 2 needle nose pliers( a must) some time( like 2 hours the first time) and a good eye.
1.) remove front rack.
2.) remove side panels.
3.) reomve the gas tank cover.
4.) remove the gas tank.
5.) remove white plastic under gas tank.
6.) remove the left side cover, where the pull start is.
7.) remove the pull start.
that is what comes off to do it.( sounds worse than it is) now, you have to get the piston to top dead center. the manual or the c.d. will show you exactly how to do it. use the 2 needlenose instead of the special tool they require. buy a good set of feeler guages from yamaha, or a mototcycle shop. cost is about $5.00 for the set.
i did mine the first time, and was shocked that a dealer would charge us $200.00 to do this. by the 3rd time i did it, i got it down to under an hour!!!
good luck!!!
my pictures
Old Aug 30, 2002 | 09:12 PM
NorthernEdge's Avatar
good info mich I'm going to archieve this post for future reference!
Old Aug 30, 2002 | 09:38 PM
PADZZ's Avatar
Speaking of the CD's (an absolute must have)...PM me if you are interesed in one.[img]i/expressions/face-icon-small-wink.gif[/img]
Old Aug 31, 2002 | 02:25 PM
Jeff660's Avatar
Do you need a new valve cover gaskets?
Old Aug 31, 2002 | 08:59 PM
the gasket is an o ring. if you are easy on it at all, then it will be fine.
my pictures
donintennessee
Jan 8, 2021 12:40 PM
greg74
Sep 10, 2019 03:03 PM
Jul 28, 2015 12:12 PM
hondarider1234
Jul 21, 2015 11:53 PM
MNatv89
Jul 7, 2015 11:36 AM
