Torque Stuffer
Old Sep 3, 2002 | 11:49 PM
miwolf's Avatar
What's up gang. I'm trying to find a sight I can order a White Brothers torque stuffer
from. Can't seem to find one. I have a 2003 Black Wolverine & would love to have a little more bottom end.
Old Sep 4, 2002 | 11:15 AM
WarriorManiac's Avatar
miwolf, Albaaction.com has one. Believe its their own not the White Brothers. I belive I have seen the White Brothers in my MotoJoe catalogue.
Old Sep 4, 2002 | 12:06 PM
YZGUY's Avatar
Just order direct from WB.
Old Sep 4, 2002 | 04:52 PM
slowride1's Avatar
WarriorManiac is right AlbaAction.com has and it is White bros. product. It is a little bit of a b!itch to install it though! You have to either grind or file the inside of the headpipe to make it fit!
Old Sep 4, 2002 | 07:50 PM
miwolf's Avatar
What's going on guys. Thanks for the info. Just wandering if the torque
stuffer really makes that much of a difference & is it worth the pain of the install????????????
Old Sep 4, 2002 | 10:00 PM
LotusPosition's Avatar
It's not THAT tough to install. All your headpipe will need is a little grinding with a die grinder or Dremel tool. I would estimate that the grinding aspect of the job took 10 minutes.
I don't really know of anything else costing only 30 bucks that will help low end. Give it a go.
Old Sep 4, 2002 | 10:06 PM
Mine didn't need any grinding. Slide right in no problem. Can't really say that I noticed any difference, did it with other mods.
Old Sep 5, 2002 | 05:18 PM
slowride1's Avatar
I must of filed mine for about 2hrs. It had weld splatter all over it. The guy that welded it must of had a bad hangover that day.I dont have a dremmel so I had to do it the old fashion way.
Old Sep 7, 2002 | 09:21 AM
miwolf's Avatar
What's up guys!!!!!! Thanks for all the help. I just ordered a
W.B. R4 exhaust & torque valve. Now I can't make my mind up between
the Pro Design air filter set up or the K&N power kit. Any Suggestions??????
Old Sep 7, 2002 | 09:24 PM
The Pro Design is one of the best things you can do for your bike. The factory setup is not the best. If your filter is not on right, dirt can bypass it and ruin your engine. The Pro Design is a BIG improvement in that respect. There is also a K/N filter to fit the Pro Design, if that is what you want.
