wierd noise grizzly 660
Hey guys, take the wheel off and put some grease on the mounting flange, then put it back together and try it. Make sure the lugs are tightened good. Mine did this a while ago and this is how I fixed it. If this doesn't work, remove the axle nut and slide the axle out and grease the splines, I have heard of others having to do this also. Hope this helps.
jrooker6
04-23-2016 07:36 PM
mrtidy
02-03-2016 05:00 PM
