ok knew question
Old Sep 19, 2002 | 08:23 PM
BansheeRidder's Avatar
my banshee is getting really hot after riding for a while, which it is supposed to do i know. if i change my radator will it make a big difference?
Old Sep 22, 2002 | 12:58 PM
RaceWarrior350's Avatar
Try Asking a local expert like Ryan Eshelman,Jeremy Henry,David Knowels Or Sam Reel. These people should be able to tell you. I do beilve a radiatior would help but u dont need a radaitor without pipes filter ect. u could try a high flow water pump impeller. Pick up a manual and do it urself. I think david knowles has a manual he would sell u. ;p
Later
Old Sep 23, 2002 | 01:15 PM
95wolv's Avatar
Definately check the water pump impeller,years back my buddy had a lot of problems with his 'shee puking coolant whenever it got worked hard,turned out the plastic impeller it comes stock with was partly melted,replaced with an aluminum one,and it made a big difference. They do make larger,high capacity radiators for the Banshee,but check into the pump first,could save you a lot of money,and if you do open it up,put the aluminum impellor in even if the plastic looks ok,it will make a real difference.
Old Sep 23, 2002 | 06:32 PM
ryenol's Avatar
The impeller would be cheaper initially, and all you gotta do is drain the oil, pull the clutch side cover, remove the c-clip, the plastic gear, the little dowel pin (going through the shaft) and there you are..
Old Sep 24, 2002 | 09:34 AM
ct330's Avatar
defently get a alum. impeller, run engine ice insteed of 50/50 coolent / water, and strip all the dam paint off the radatior.
1ArmBandit
55
Oct 14, 2015 09:03 PM
bigred20653
Oct 2, 2015 10:05 AM
mark23
Oct 1, 2015 09:57 AM
Nosniborpapa
Sep 19, 2015 07:07 PM
bvolks
Sep 13, 2015 12:57 PM
