Help With Tires For 2003 Blaster
Old Sep 25, 2002 | 10:09 AM
Kyonic's Avatar
Hi i have a 2003 blaster and i am wondering what tires i should get? I dont really want to have to change the stock rims the tire size on my Blaster are this both rear are AT21x10-8 what does that mean. if i dont change my rims can i still get holeshots what size tires can i put on my stock rims
Old Sep 25, 2002 | 12:03 PM
RaceWarrior350's Avatar
whatever you do dont go holeshots if u wanna ride in the woods ours got stuck all the time. go maxis razrs or GBC Shredders.
Ryan
88 Warrior
K&N With airbox removed
Pro Circuit T-4
Jetted
DP Racing Brake Pads
DG Alloy series Nerfs
Duro Rears
Fresh Rebuild
Plastics Redone
99 Blaster
FmF Fatty Gold Series Pipe
Power Core 2 Silencer
-Crew-
Dave-Z400/KDX200
Ryan-Warrior
Sarah-Blaster
Jeremy-300ex
Old Sep 25, 2002 | 02:37 PM
CBUS660R's Avatar
21x10-8 reads like this
21= tire diameter(height) in inches
10= tire width in inches
8= rim diameter in inches
all ATV tires use the same format
when you go to buy tires, look for the -8, this size will fit on your stock rims
Old Sep 25, 2002 | 03:31 PM
YZGUY's Avatar
When we had a Blaster, we ran the 20X11-8 Holeshots, which will fit on the stock rims. Because they have a square profile and are wider, they give the bike a lot more stability compared to the balooney stock tires.
Old Sep 25, 2002 | 04:10 PM
Peltrax's Avatar
You can fit basically any tire that is for an 8 inch rear
velcro7279
Aug 24, 2015 01:15 PM
1966F100
Aug 21, 2015 07:10 PM
scott1988
Aug 18, 2015 08:44 AM
suzukiquadrunner1987
Aug 9, 2015 08:45 PM
315blaster
Aug 8, 2015 08:13 PM
