raptor cdi boxes?
Yamaha Raptor 660R Camshaft Specs
VALVE LIFT DURATION DURATION GRIND
Int. Exh. Int. Exh. @ .050 NUMBER
0.340 0.355 260 260 232 461/496 WebCam
0.340 0.355 270 270 242 696/697 WebCam
0.365 0.365 275 275 248/245 736/737 WebCam
0.335 0.370 254 246 - Stage 1 HotCams
0.384 0.405 246 259 - Stage 2 HotCams
0.320 0.345 232 235 - Stock Raptor
These are the specs for the available cams for the Raptor, as well as the stock cam
Regards,
Rog
Regards,
Rog
The only thing else I would be interested in seeing is the "lobe center" for the intake and exhaust for the stage 2 cam.
Anybody have these specs for any of these cams?
I know I have the lobe center for the 461, 696 and 737 cam around here somewhere (dam office is a mess).
Oh, here is the 461 cam lobe center 106 degree Intake and 107.5 degree ex.
I'll keep looking for the rest fo them.
I am having a custom ground cam being made as we speak and I am hoping to have it back in the next week. Chances are it should be alot better then whats currently available by what specs I have seen from Web and Hot vs. what my new cam will be.
thanks for the info.are the hot cams duration numbers given at .050 lift or they using some other number.if i remeber correctly i think their given at 1mm witch should equal .039 inches.kinda makes it confusing when tring to compare,lobe center would help.its interesting to see the two companys differant approches to cam design.
#15
Thanks 2-S-D!
Yes, without the decomp mechanism and higher comp (especially 12:1 or higher) it will cause you fits. I know, I am going through it right now.
Just make sure your battery is always fully charged and you'll be fine. Start-up for the first time of the day seems to be toughest for me. Once she's warmed up or been started once during the day, no problems at all.
If you keep the decomp mech though, it causes fits for you if you trail ride at all. Lugging it is just a pain with it.
Always a trade off somewhere![img]i/expressions/face-icon-small-wink.gif[/img]
Thanks again for the Stage2 lobe centers.
Derby, your right. If they give you the specs at something other then .050 then it makes things hard to compare. Usually on Web you get 2 different specs though. A duration number and a duration number at .050"
Anybody care to comment on how Hotcam provides their numbers?
#17
I replaced a 736/737 web with a stage II cam friday night in my trinity 686. The bike is much quicker in the mids and top end. I have a friend with a banshee that would easily pull away from me when he hit third gear. Well, that is not the case anymore we are dead even throughout the run.
The compression release from the stock cam fits right in the stage II cam.
#18
swytak,
Thanks for the info, can I get some more? What piston bore do you run? What
comp. piston, make? Have you had any head chamber work done? And what cam
( duration? )
Have you had any starter clutch problems yet with the no decompression setup? I
know I have replace mine and one other one already and wondering if this is going
to
make it worse! Thanks for any info.
PS. what's your signature all about ?? "The Compound"-(FSW)
( duration? )
to
#19
Talked to Scott today at Dyna. He told me that they were still a few months away from a raptor CDI. Says not much intrest in them. I was on a cell phone with bad reception but i think he said trinity was testing the only on made so far?? I asked that question twice. Cell phones. Anyway do not look for one under the christmas tree I talked to a company that does buick GN stuff and he said he would like to........LOL
#20
Good post 14, really!
So it looks like if we (Rap owners) want this product, we all need to "overwhelm" Dyna with e-mails and/or phone calls, telling them there is a demand for them. Maybe, just maybe they will pick up the pace and get these things made for us by Christmas!
Here is their e-mail: info@dynaonline.com
Here is the phone number: (626) 963-1669
If there is interest, call or e-mail them and make sure to tell them there is a definite interest for this product!
